Hey all! I finally mastered applying KSG and put on about 4 layers over the course of a couple of days last month. Its been working pretty well except for the hood and roof. Water seems to bead great on the sides of the car, but when it comes to the roof, hood and tailgate the beading is not nearly as effective. I've tried applying an extra layer but still no improvement. Also, it seems like the sealant's slickness has diminished to the point where the paint sqeaks when I run my finger across it after washes. Needless to say its made drying more of an ordeal. I can tell the sealant is on there though since water still beads.
I'm planning on topping it off with some FK1000p when it comes in on Friday, but I'm just curious as to why this is happening. I've been applying it very thin and buffing it off after 15 or 20 min (any longer than that residue becomes extremely difficult to remove on black paint).
PS. What is your technique for applying? I've been using a yellow foam applicator pad that I hit with a couple of sprays of diluted ONR. Once it's moist I hold the applicator against the bottle opening and shake it a couple of times. Once the SG is on there I rub it in to the applicator to even it out and then start applying. It's time consuming when you are trying to do the whole car in a hot Florida garage, but its the only effective way I've found to apply it thin. Anyway, if there is a way to make the process easier I'm all ears.
tl;dr KSG isnt beading well on my hood, roof and tailgate but beads perfectly on the sides. What gives?
:help:
:help:
