Is there any difference between these 2 backing plates?
Hi-gloss pads are the newer pads which offer:
"This new, patented, Constant Pressure technology uses a layer of engineered, instant rebound foam between the pad and the backing plate to absorb off-axis movements while keeping the pressure of the pad on the surface constant. It allows even beginners to achieve professional-like results."
Otherwise no real difference from what I can see.
