Broadly speaking, there are 3 types of matt-finishes:
Proper:
1. Using a matt-clearcoat.
2. Using a regular gloss clearcoat, but with matting agent added in.
Budget:
1. No clearcoat at all!!
Many detailers, when faced with matt-painted cars, have often used the same techniques as per gloss clear-coated finishes. Many find this acceptable but many re-sprayers, custom sprayers and some paint manufacturer’s technical personnel have a different view point.
They feel that a freshly sprayed matt-finish’s looks will "change" after heavy buffing with wool pads. I agree that rotary buffing with wool will add a slightly glossy look that imparts a satin effect to the matt finish.
Some owners don't know and don't mind, while others will freak out. Even if strong chemical washing is employed to remove this slightly glossy effect due to aggresive compounding, it still cannot revert 100% to the original freshly sprayed matt look. Hence, many sprayers avoid sanding and wool buffing a matt paintjob.
If the car owner doesn’t realize this, then it’s fine.
But if the owner is already accustomed to how his/her matt finish looks, and you’ve ruined that original look, they might not be too happy.
Everyone has their favourite method to deal with matt finishes .
The below steps are my personal favourites and just wanna share with everyone here.
On non-problematic matt finishes
Thorough washing and claying, followed by a pure WOWO carnauba (eg: S100) or a synthetic wax applied using WOWO (eg:Collinite 845). Both are easy to use and 100% problem-free on matt finishes.
Note 1:
Certain waxes can cause streaking and patchiness on matt surfaces.
Maybe that’s the reason for Swissvax introducing a new carnauba specifically formulated for matt finishes.
Note 2:
Klasse AIO applied with PC or DA can cause very distinct smudges, streaks and patchiness that cannot be buffed away by MF towels. If you hv to use an AIO to cleanse the paint, you can follow up with a very fine abrasive polish or glaze to remove the patchiness. It works, but will darken colour slightly. So, be sure to do the entire vehicle. And then…apply LSP.
On problematic, neglected matt finishes.
To avoid any misunderstanding, inform the owner that if the defects must be removed/minimized, then the colour could darken a wee bit, and it could have a very slight satin look.
Prep:
1.Use whatever surface prep/compounding techniques you normally use.
Personally, I avoid wool and compounds. I’ll use any fine-cutting polish such as Megs 205, Menz106, Menz 85.
2.Wash entire car with dish washing liquid or any de-con wash systems.
3.Wipe with alcohol.
These steps will reduce/remove as much compounding-generated sheen as possible.
Polish:
Don’t bother, cos it’s a matt finish. You won’t see the effect except for a slight darkening/richening, which the owner might dislike.
LSP:
My personal favs are Collinite 845 and S100 applied using WOWO technique. 100% no smudges, and so easy to do. No noticeable darkening or glossing of the paint finish, but does make maintenance easier.
For QDs, anything goes. My fav is Megs UQD cos it has no darkening effect on matt finishes.
Example of a neglected matt finish:
Lots of tree sap stains and watermarks that could not be removed by hand-application of products. Camera could not capture the severity but it was bad. Stains have been there for 4mths, baking under the hot sunlight.
Action:
1. Pre-soaking with vinegar to loosen whatever minor watermarks.
2. Shampoo wash and clay.
3. Megs 83 DACP + Yellow pad + rotary
4. Menz 85 RD + white pad + PC
5. Wash with dish washing liquid. IPA wipedown to remove oils and any slight gloss.
6. Collinite 845 using WOWO.
Work-in-progress. Stains removed, and washed again.
Awaiting LSP.
All problems were removed and owner was shocked when he saw the car, exclaiming "FFFFxxxxxxK!!!!, looks great
To me, that makes my day!!
Proper:
Budget:
Note 1:
Note 2:
Prep:
Polish:
LSP:
Action:
Awaiting LSP.
