How much pressure when using Purple Foam Wool pad on DA?
Boston Man
How much pressure am i supposed to apply when using a 3.5" Purple Foamed wool pad with a g110? Same as a regular pad?
Gonna try to remove 2000 grit wet sanding marks.
I apply about the same amount of pressure as with a foam pad, but you won't always *need* a lot of pressure as that pad/product combo will cut pretty well on most paint. The PFW compresses down mighty thin if you apply too much too, so don't use more pressure than necessary. But OTOH it doesn't get really hot the way orange foam will, so there are some good trade-offs too.
