How many times to use claybar before tossing....
I've used several different clay brands, including Mothers, Clay Magic, Meguiar's, Zaino.
Most times, after claying, I simply "wash" the clay with carwash soap and water and store in a zip-lock bag until the next use.
Then after claying about 3-4 cars, I pitch it.
Do you guys toss it every time?
I've heard of guys using a single clay bar for 6 months, maybe 20 cars! Is that wise practice?
(Yes, I am aware of the "drop-it-toss-it" rule, but I'm talking about normal use here.)
Thanks........Bill
How do you wash clay ? :nixweiss
I haven't tried it, but I would figure, the dirt and grit would be hard to get out.
I also use about 1/3 of a bar, use it then throw it away because it looks like it's too far gone when I'm done.
I like the the Schlegel Gray Ghost detail clay, I cut my bar into quarters.
As for durability, it depends on the car. Today I detailed a 2004 Nissan Altima. I washed it, then clayed it. There was practically no contamination of the clay, so I can reuse that piece. The 1999 Ford Escort ZR2 that I detailed on Monday had so much crap in the paint that I had to cut the quarter sections in half, and I still went through half a bar of clay!
I also have been known to "shave" the contaminated surface of a section of clay, leaving a fresh layer of clay to continue with.
Basically, when I'm finished with the vehicle, I take the clay and submurge it the the soapy car wash water. Then just pull and fold the clay underwater like a "kneaded eraser". Usually pull and fold for about 3 or 4 folds.
When the clay comes out of the wash water, it's pretty darn clean!
I use Pinnacle Poly Clay. What I do is cut it into 1/4 sections. Then flatten it out real good, do usually the whole car, assuming it isn't too bad. Then I pitch it. Never tried rinsing the stuff out though.
Luster,
I also have been washing my clay. Not sure how many uses I get out of it. I just throw it away when I begin to have trouble getting it to look new through washing.
forrest said:
When the clay starts to change color, and it doesn't seem as sticky as new, toss it.
Same here. There doesn't seem to be a set amount of vehicles per clay bar, but more what you are removing from the paint of each one.
