How do you detail Carbon Fiber?
milani
Member
My New C230 has carbon fiber inserts on the dash, door and console. What are the best methods for detailing. I was using Plexus on my woodgrain in my old C240. Would this produce the same results, or should I try something else? I am afraid to try anything since it is brand new.
Help!:scared
I spent quite a bit of time searching last night on this topic and came up pretty much empty handed. I think a QD would work and is safe for buffing up and removing fingerprints. Scratches are another subject. I'd be tempted to try a plastic polish or if that didn't work PS21 MFR. Definitely report back on what products you use and your results.
Russ
Since CF is (usually) covered in 3-4 layers of clear coat lacquer, surely you can just polish and wax as normal?
NickATRvtec is absolutely correct. It is sealed, I would use something like 303. Not anything to worry about
