Black is a beautiful when it's clean (for oh, maybe three minutes after you wash it!)
I have three of 'em. I can tell you that black is not the color to own if you're obsessive w/ meticulous finishes. They can however reward you as quoted here:
Macko said:
There is a lot to learn & it can take over your life but nothing beats having the best car in the car park & knowing it's all down to you.
Truer advice has never been given on this board:
Macko said:
I'd say before you do anything you need to read everything you can about the correct washing technique. All the glazes, waxes & sealants in the world will be wasted if you end up swirling your paint each time you wash it.
Washing techniques for
my black cars:
Work tires, wheels and wheelwells first using dedicated equipment.
Remove grit (if present) w/ a pressure washer then switch to 3/4" hose w/ a hose end sprayer and car wash solution and spray down car.
Rinse with a firemans nozzle.
Use two 5 gal. buckets, one w/ two grit guards (stacked) for rinsing mitts and the other w/ 2 gals. quality car wash.
Starting on top panels, spray w/ hose end nozzle and car wash solution (provides additional lubrication for wash) use a quality wash mitt and
glide the wash media along the panels in a straight line motion, rinsing the mitt between panels w/ firemans nozzle and medium pressure/dispersion.
Dunk mitt into rinse bucket and agitate well then dunk into wash solution in second bucket.
Move to the other two top panels, gliding and rinsing mitt as you go then rinse the top portions completely w/ nozzle.
Get a second mitt and do the upper half of the side panels and trunk areas using same car wash solution/rinsing of mitt etc.
Get a third mitt and repeat process for lower half of car reserving the lower bumpers, behind wheels and below doors areas for a grout sponge.
Rinse all again and use electric leaf blower to remove about 80% of the water, then use quality mf to finish drying, starting w/ windows then lightly going over spots.
This process seems time consuming (and is compared to slam dunk wash jobs) but with time and quick connects it speeds up and there is
no grit in my rinse and wash solution buckets, in fact, I save the remaining wash solution to do wheels/tires next wash:heelclick.
