Michaelelts
I just got a foam gun off of ebay it is a little different from the one Bill D and accumulator have in that it is a fixed ratio 4oz to 1 gallon dilution. It is great especialy since it had snowed here in VA and I need to clean off the cars of salt spray. I am playing around with the diltution and getting a more very soapy spray rather then foam. In part it may be because I am using Maguirs Crystal rather then NXT( can't find it localy) I have some EO that I will try as soon as I use up the crystal. Do you guys use the soap straight in the resevoir or mix 4oz to the resevoir and fill with water? I am trying to get foam instead of the soapy water. I love it even as it is, it still makes washing much easier and faster.
