Factory Painted Wheels ????
Vettecor
I have a 1994 Lebaron GTC Convertible. It has factory white painted wheels (mags).
I have used simple green, A2Z, and greased lightning to clean them. The backs look brand new. The fronts with disk brakes will not come as clean. The wheels have all these small openings that will come clean with armorall cleaner and a q-tip but I don't want to spend hours doing this.
Anybody have suggestions on what I can use to spray on the wheels and hose off that will work?
The openings are too small for most brushes to work!
The idiot who designed this type of wheel should be shot....
Thanks guys
Larry
Gee, if A2Z isn't doing it for you...... :nixweiss
You're spraying it on dry right?
Maybe QD the holes after every cleaning and then use A2Z and see if that improves cleaning.
