I have used Lexol Cleaner/Condidtioner thinking it was the best. Now knowing about clear coated leather and reading about how Lexol will just deteriorate the coating, I need to know that if leather is clear coated, how would you clean it. Would you use the same cleaner you use for the vinyl. I use Griots garage interior cleaner...should I use that (its a multi-pourpose cleaner designed for plastic, vinyl and non-coated leather. Sory, I know we covered this quite alot but couldn't find an awnser. Also, what cleaner would you use to test the leather to see if it is clear coated? Thanks alot for your help -Brad
