Duplicolor primer as a base for catalyzed paint?
shifflav
As a result of a failed spray gun, in haste I sprayed the area I repaired with body filler with Duplicolor rattle-can primer to offer a small bit of protection. It sanded out ok, but my inexperience makes me question if the good catalyzed paint I will be applying soon will have trouble adhering to the cheaper primer. Any suggestions?
What do you recommend I do next? Should I sand off the Dupli-Color primer and then put on a good primer? Or, can I put a good primer on top of the Dupli-Color primer?
