DG 105 over Optiseal
shadow85
Is it worth putting down a layer of optiseal, and then topping with DG 105 worth it? Or should i just go straight to the DG 105?
Dan said:
DG105 will remove the optiseal as it has pretty strong cleaners.
Yep, if anything top the 105 with Opti-Seal. Don't see you are going to get a huge improvement however.
That makes a lot of sense, being its a cleaner wax. I guess there's also no point to attempt to layer it as well...
