Deep Gloss Auto Salon: 360 Challenge Stradale
Deep Gloss
Jason@Deep-Gloss.com
*It has been quite some time since I?ve posted any of my work. I have just been too busy to dedicate time to taking pictures while working and to do a proper write up. I have had several requests to post this vehicle, so, on with the show!*
The Challenge Stradale is a 360 Modena on a double dose of steroids from the planet Crypton.
The exterior changes from other 360s are subtle, but that is where the subtlety ends. One of Mr. Moruzzi?s goals with the Stradale was to shave three seconds of the 360?s Fiorano lap record. Suffice it to say, he and his team were successful.
Once you enter the Stradale it becomes very evident that this car is all business and shed as much weight as possible. You won?t find carpet, in its place is rubber floor mats. The seats are carbon fiber and this specimen has the wonderful Alcatara. You also won?t find a stereo in the Stradale, the music is the purr of the all aluminum V8 that hits 60mph in 4.1 seconds and stops by means of the Enzo carbon brakes and changes gears in 150 milliseconds.
Enough of my banter, on with the show.
As always, the wheels were the first items attended to. Due to the sensitive nature of these carbon/ceramic brakes, careful product selection is needed as to not induce damage to them and render them useless. For this task P21S wheel gel was used with various brushes
Below is an action shot of me using my beloved Raceglaze XL wheel brush. This tool won?t spit back on you like many brushes; it is sturdy, effective enough to clean yet, won?t scratch and, it?s very thin. I mention it being thin because this is my favorite feature, as you can see it even fits between the very small clearance (tight tolerance) of the rim and the caliper.. Love it
After the wheels were done it was time to do something about bugs that met their death on the front of this stallion and it was also time to address the road tar that was on the lower body panels. The front end and lower portions of the vehicle were showered with water via pressure washer and then, treated with 1Z Einszett Anti-Insekt Bug + Tar Remover. It was left to dwell for 3 minutes and then pressure washed off.
From there the entire exterior of the vehicle was showered with water via pressure washer to dislodge as much debris, dirt, contamination as possible. After showering with just water it was time to use the foam cannon. A strong concoction of several soaps and cleaners was sprayed onto the exterior and left to dwell for several minutes.
Please note: While it appears that I am in the heat of the direct sunlight, it was a mere 50 degrees F while washing therefore, no water droplets or foam was evaporating onto the paint.
After dwell time
After the foam dwelled it was then pressure washed off and foamed again, this time with Duragloss #902.
It was left to dwell and then a proper 2 bucket wash was performed using Duragloss #902 and an Uber sponge from Detailers Domain.
After washing every square inch of the exterior body panels, the vehicle was pressure washed clean and then further decontaminated using Riccardo yellow clay and Optimum No Rinse as a clay lube. While claying I was rewetting the vehicle to prevent water from dying on the body panels.
After claying, the entire vehicle was blown dry and then residual water was blot dried using high quality Chemical Guys micro fibers.
Below are some post wash pictures. As you will see there was a solid mix of holograms and swirls/scratches throughout.
All sensitive bits were taped up to protect them from damage and it was time to get to business? Paint correction!
As always, a test section was picked to determine the best and least invasive course of action that would get this paint back to its glory. F-Cars of this vintage usually have paint on the softer side of the spectrum and this vehicle was no different. I called Mr Bob Willis to ask him a question about the racing stripe, thanks for the time!
The paint correction process was a 4 step process for the areas with deeper inclusions and a 3 step process for all other body panels. Below are my paint correction steps:
? Body panels with severe damage were polished with Menzerna Intensive Polish and orange Lake Country Pad
? All panels (including aforementioned panels) polished with Menzerna Intensive Polish and white Lake Country Pad
? All panels polished with Menzerna 106FF and black Lake Country pad
? All panels jeweled with Menzerna 85rd and Lake Country no cut red pad for high gloss
91% IPA wipe downs (multiple) were performed to ensure that the correction observed was true and that no carrier oils were acting as unintentional fillers.
The test panel was determined the first night of delivery and inspected under many different light sources.
Before and afters at various phases of correction process:
After pictures at various stages of correction process with various light sources:
Brinkman:
Fenix:
Camera Flash:
Halogens:
The next morning, I pulled the vehicle out into the sun to validate my correction process steps were robust. Below are pictures of the ?in sun inspection?.
And another later in the day:
The engine bay was also given much attention and really was brought back to life.
A thorough wipe down with a spray bottle filled with ONR was the first step.
The carbon fiber drain channels had lost all clarity and shine. The carbon fiber air intakes, while not as bad as the drain channels were also treated in a similar manner as follows:
Duragloss #501 was used to chemically clean and seal the carbon fiber.
Hand polishing with Menzerna #205 and a white polishing pad was done.
Carbon fiber areas were then sealed with Zaino AIO and Z2
The reason #501 was done was because we thought that would be all it needed. After it was completed by my assistant, he called me over to inspect and I then determined that a chemical cleaning was not sufficient and that more life/clarity could be given to these areas and thus, the hand polishing and Zaino treatment was done.
The metal exhaust can was hand polished and then topped with Surf City Diamond Edge Metal Dressing. All rubber bits in the bay were dressed with 303 Aerospace protectant.
Below is a picture that is representative of the condition of the carbon fiber drain channels in the engine bay
After:
Before:
After:
Full After Shot:
The Plexiglas (weight reduction) of the engine deck lid was meticulously cleaned with waffle weave micro fiber towels and Surf City Clearly Better glass cleaner.
The interior seats are wrapped in Alcatara leather and were in great condition (Thanks to Mr David Fermani for anwsering a question I had about the Alcantara). It is very obvious that the owner of the vehicle takes great care to keep the interior in as good of condition as possible.
Below is the process for the Alcantara:
Vacuum
Dry agitation with a gentle bristled brush
Vacuumed
A white, small, damp terry towel was used to clean
Left to dry
Dry fluff with gentle brush to restore to showroom condition
The interior is also laden with carbon fiber; the carbon fiber was in just as good of shape as the rest of the interior was.
Below is the process for the interior carbon fiber:
Wipe down with FK425
Treated with Zaino AIO
Sealed with Zaino Z2
The leather dash was cleaned with Leather Master and then treated with Zaino leather in a bottle
Rubber flooring was cleaned with all purpose cleaner and then treated with Meguiars M40
Below are the only 2 pictures I managed to take of the interior (excuse the drivers florr mat as the owner had just pulled it into the sun light for inspection):
Rims were treated with Zaino AIO and then sealed with Zaino Z5.
Exterior seals/weather stripping cleaned with all purpose cleaner and then treated with 1Z Einzette Gummi Pflege
Interior seals around trunk lid treated with 303 Aerospace protectant
The LSP of choice was Black Fire Wet Diamond Sealant (3 layers) topped with Duragloss Aquawax.
I would like to thank Deep Gloss for sharing his awesome work here with us at TID, awesome work Jason and that shine is so wet!:drool5::drool5::drool5:
Thank you Angelo.. My pleasure.
Glad you enjoyed the write up!
Wow DGS, I don't know if I'm more impressed with the car are your write-up :)
Thanks for taking the time and effort to post with us at TID :rockon:
Thanks Flash, this is the main reason I haven't posted lately. Taking in process pictures takes a lot since I get so focused at a micro level that stopping to take pictures is very hard for me.
Nice work!!! :)
Thanks Camo
Wow Jason, that is AMAZING! The CS 360's are some of the coolest modern Ferrari's ever made and are absolutely raw. Did this one have an aftermarket exhaust? The way these things sound with a Tubi will give you goosebumps..
Top notch write up and detail. I always love to see your work.
Thanks a lot broker... I appreciate the kind words.
hey Todd:
Thanks man.. I agree, the CS is a very raw beast. Not something you would want to take for a long trip!
No AM exhaust on this one.
Amazing, I can only hope to get that good. I need to get some of the Blackfire on my next order, what a shine.
Thanks Indy... I am confident you will love the sealant!
Trust me, if you want to improve your skills and are determined to learn, you will acquire some great skills and put out some great work..
Thanks again
That has to be one happy owner!!! Car looks fantastic!:D:D:D
Thanks Luster.. The owner was very happy.
As he was walking around the car I was taking some final pictures. I have a few with him in the shot and I noticed later that he had a HUGE kool aid grin on his face!
very nice work... nothing shines quite like a black car
Thanks.. Agreed, When black is correct and the clear is flush there is nothing that looks better
Had to come back for some more Ferrari treatment.......:drool5::drool5::drool5:
Thanks again Sir... Glad you liked it!
WOW!!!! i see why you're so busy... great work and superb write up.
Thank you for taking the time to look. I have been VERY fortunate this season. Busiest season yet!
The paint looks perfect! Great job of sucessfully planting yourself within a very difficult Metro Detroit market. Top notch. :drool5:
Excellent writeup and beautiful work.
Thanks FJF.. I appreciate the kind words
Senor Fermani.. Thanks man... It is an interesting market up here... I just wish we didn't get snow so I could do this year round and make it my primary source of income
amazing work, Jason!!! How do you like 1Z ani-insekt???
Thanks SC'd... I am VERY impressed with it... I haven't used it extensively enough to emphatically say it is the best I have tried but I will say that I am very hopeful!!
