Correcting this advanced Florida sun fade...
bradleyheathhay
Hey good ppl. I'm on the search for a used truck, and I'm finding that if I don't mind doing some paint work I can stand to get a good deal. My searches have been further down south to avoid the frame rust that's common in these trucks, but that means I'm running into some with advanced sun damage. But that's ok, because I can sand and fix peeled paint (novice), but I can't do a thing about frame rot.
This is a 2006 Silverado I'm thinking about driving to see, and I'd like to get an idea of what it's gonna take to fix the paint. You can see the entire hood and probably roof are faded/oxidized(?), as well as almost the entire passenger side bed panel. I am not a perfectionist at all compared to the usual auto body paint perfectionism standard. I just want everything to look good from ~20-30 ft away.
So, taking this restoration one section at a time, what's the process gonna look like to sand and re-coat all these panels? Orange peel is something I'd really like to avoid.
Thanks.
That, unfortunately, is too far gone to correct. It will need to be repainted. The clear failed long ago, and the southern sun just killed it...
Good luck in your search!
The rest of the paint is also the same age as the failed paint, so it would be best to repaint, as Scott has already said above...
To help avoid orange peel, you need to spray wet coats, that do not run...
Is GM production paint from this era more prone to clear coat failure or is it just because the truck sat outside in the Southern sun which damaged it as pictured here??
I know some may think that if the clear coat surface was "properly" maintained throughout its life this delamination or peeling of the cc-bc-primer would never have happened, but being exposed to constant sun from being parked outside during its lifetime may not prevented or at least mitigated what is pictured here.
It is a nice looking truck for that era with no signs of salt corrosion on it like SO many of the trucks of that era driven year-round here in the Upper Midwest. It's scary to see them on the road and makes one wonder if the brake lines are rusted that much as well.
