The traditional hose and 2 bucket method has an inherent flaw. We often apply a low-pressure rinse which is incapable of removing bonded abrasives. While washing, we mechanically agitate the surface with the Wash Pad, dragging the bonded abrasives across the surface. Our comprehensive BOSS Foaming System offers two approaches for washing...
PRE-WASHING
An incremental step to traditional washing
Ridding the surface of abrasives and contaminants prior to your wash process by using specially formulated foaming detergents to chemically soften and encapsulate contaminants then allowing gravity to carry the encapsulated particles to the ground.
TOUCHLESS WASHING
A replacement to traditional washing on frequently cared for vehicles
With routine maintenance, for removal of light to moderate road grime and contaminants, the BOSS Foaming System may deliver touch-free washing employing a two step system. Completely eliminates mechanical agitation of the surface, virtually eliminating wash-induced scratches while maintaining waxes, sealants, and coatings.
THE BOSS FOAM CANNON
The ultimate foam delivery system
Are you tired of pre-mixing your foaming solution for every car? How about a cannon where you spin a bottle of concentrate on and knock out 35 average size vehicles?
Our exclusive Auto-Mix feature is a serious innovation. It saves tons of time because you don`t have to remove the reservoir and remix the product by hand... It`s a "no measuring, no mess, and no math" proposition, just screw in the bottle
of concentrate and the Sure-Flow Metering Tip provides the proper 20:1 ratio. It sprays for days… One bottle washes up to 35 cars...
1. Auto-Mix Method
Remove jar from cannon, pour concentrate into jar or screw on Griot`s Garage 35oz. bottle
to internal cap threads. Select the appropriate metering tip from the chart below and
insert firmly into the pick-up ball at the bottom of the poly-tube. Note: Tip will be
dependent on the type of pressure washer you have. (See AUTOMIX
tip recommendation
chart below)
2. Manual-Mix Method
Dispensing of pre-mixed, ready to use (RTU) solution (Water: Detergent). This is the
typical method, requiring the user to pre-mix a concentrate prior to use. Traditional
products require 2-3 ounces of concentrate, while BOSS Foaming System products are
to be diluted 20:1 using 1.6oz of concentrate to water (32oz). See reference chart of
common applications of Griot`s Garage products below.
FOAMING SURFACE PREP
For a deeper clean prior to paint correction
- Rids surface of abrasive particles, avoids wash-induced scratches
- High pH levels breakdown waxes and sealants, providing a clean slate for paint correction
- Ground-up formulation blended for THE BOSS™ Foam Cannon Auto-Mix system
- Dual-layer foam formula extends dwell time, enhances cleaning action
- Primary foam clings to paint, softening road film & organic contaminants, while secondary foam releases and carries the abrasives to the ground
- Extended dwell times… up to 10 minutes of intense cleaning action
- 20:1 Dilution ratio vs. the common 10:1 dilution of most competitive products.
Dilute 10:1 in our Italian made PUMP-UP Foamer or Foaming Surface Prep Secondary Bottle (Item# B3312) for an intense cleaner which makes quick work of bugs, road slime, bird droppings, grease, and grime. Ideal for paint, grills, bumpers, engines, tires, wheel wells, and a pre-spray prior to Foaming/Washing.
B3103 - 35oz
B3101 - Gallon
Associated Products
FOAMING SURFACE WASH
SUPER-CONCENTRATED RICH & FLUFFY SNOW-FOAM FOR REMOVAL OF
ORGANIC & MINERAL DECONTAMINATION
- Rich, clingy snow foam avoids wash-induced scratches
- pH-neutral pre-wash or touchless wash to retain existing waxes and sealants for routine maintenance
- Primary foam clings to surface softening road film, organic contaminants, while secondary foam releases and carries the abrasives to the ground
- Extended dwell times… up to 10 minutes of quality cleaning
B3203 - 35oz
B3201 - Gallon
FOAMING POLY GLOSS
Super paint protection and intense gloss
Foaming Poly Gloss delivers superior paint protection, intense gloss, and
remarkable water repellency. Its dense, clinging suds contain hydrophobic
polymers that enhance and protect all exterior surfaces including: paint, glass,
trim, chrome, wheels, and more. Foaming Poly Gloss also increases the
hydrophobic properties of existing waxes, sealants, and coatings while also
delivering fast drying and anti-static properties that help keep your ride clean
longer. It`s also a great way to protect components that typically go un-waxed like
grilles, aluminum and plastic trim, mirrors, wheels, and windows.
- Hydrophobic polymers enhance gloss, surface slickness, and protection
- Extends the lifespan of existing waxes, sealants, and coatings
- Produces remarkable water repelling capability
- Dual-layer foam extends dwell time, enhances cleaning action
- Delivers fast drying and anti-static properties for an extended clean
NOTE: May also be diluted ~120:1 and dispensed via our PUMP-UP Sprayer following a traditional wash delivering the same benefits.
B3303 - 35oz
B3301 - Gallon
ROUTINE MAINTENANCE
FOAMING SURFACE WASH- Pre-Wash prior to traditional wash to rid surface of abrasives to eliminated wash induced scratches (Click Pic for Video)
PRE-CORRECTION SURFACE PREP
FOAMING SURFACE PREP- Surface preparation prior to BOSS Paint Correction (Click Pic for video)
FOAMING SURFACE PREP diluted 10:1 for pre-soak via our PUMP-UP Foamer
Foaming Surface Wash via THE BOSS FOAM CANNON`s AUTO-METERING system
