Because I had the need to purchase some new brass disconnects I figured I'd try some new brands to compare against what I have.
I had some Nelson N109C brass quick connects purchased around 10 years ago when I bought my Home. They have served me well without incident.
In addition to the Nelson I purchase the Dramm set 10-22729/740 as well as the Gilmour/Green Thumb #09QCGT.These "Green Thumb" branded Gilmour's are just like the older Gilmour #09QC but without the rubber "rings" to ease in connecting/disconnecting.They are also made in China unlike the Gilmour's which are USA manufactured.
I compared all 3 on my workbench and the first thing I noticed was that the Dramm was slightly larger in their outside diameter of the female piece.The collar which you slide down to make the connection was almost double the thickness of the Nelson and slightly thicker than the Gilmour.
Next,I took a inside measurement of the male pieces, while the Nelson and the Dramm were the same ID, the Gilmour was 1/32" larger.If you have low water pressure the Gilmors are the obvious choice here.
Gilmour advertises that their Quick Connects allows the most water flow of any quick coupler and based on my measurements I would have to agree.
Lastly,I judged how easy it was to separate the couplings.
For this -Nelson wins hands down.The thick knurl in the middle of the female coupling was the easiest to connect/disconnect.Next was the Gilmour followed by the Dramm.
The Dramm has the two knurled rings on the female piece but they are at the ends of the connector.When I was done washing my car, I tried to disconnect the hose nozzle and with the Dramm QD my wet fingers had a harder time disconnecting the pieces than either the Nelson or the Gilmour.
What did I learn from this little experiment?
That you'd probably be happy with any of the three Quick Connects and any one of them would do a great job.
Would I run out and replace all my Nelson's with either brand? Nope....
But, if I was starting out and needed some QDs I would probably opt for the Gilmours/Green Thumb brand as they are almost as robust as the Dramm but,with their larger ID for better water flow and easier to connect/disconnect knurls they appear to be the #1 choice of the three.
Jeff
Jeff
