wannafbody
wannafbody
Are they the first choice for anyone? I haven't used mine yet but I think they have a lot of potential uses-tight areas and corrective work.
wannafbody said:Are they the first choice for anyone? I haven't used mine yet but I think they have a lot of potential uses-tight areas and corrective work.
wannafbody said:I was referring to PC use but I'm itching to try them on my rotary as well.
Radicalrev said:so the smaller the pad, the more cutting power it has?
Blake said:Do you need a different Counterbalance for your PC?
twista616 said:Since the 4" pad is smaller in diameter, it has less surface friction than a 5.5 or 6.5 pad...right?
Blake said:I know AutoGeek has the pads and plates. Do you need a different Counterbalance for your PC?
bcgreen said:I really don't know. When I got the PC years ago, I unpacked it and just put on the backing plate and went to work. I have read about people and the counterweights but have never found a reason to use one, so I don't know if I needed one or not.
