Are you talking about CG EXTREME AIO vs. CG Polish & Glaze ?
I will answer based on that being a yes, and if I wanted a true what you see is what you get, then I would go with the CG Ext. AIO. Plus this has a sealant, so I could move right to a LSP.
If I wanted something that had silicones, is a bit less fickle to work, and had some fillers, then I would use CG Revive.
The glaze part is not an issue, because if I wanted to apply a glaze, I would use CG Extreme Glaze.
I dont think its on the website yet, but that stuff rocks and is gives up no ground to the likes of VM.
