7424 XP Help
0inDetail0
Hey Guys,
I have a problem with my PC. The screw that runs up into the gear shaft snapped off. Luckily I was only spinning pads dry when everything fell off the polisher. Because all the other parts are pressed my only option is to replace the entire head of the polisher or drill out the screw get a new one and hope it works right.
I only use it for waxing and 3" pads because the shroud is small enough to not hang over the small backing plate. It has a use daily. Attempting to replace the screw is cheap but anything beyond that is not worth the money. I would have to drill out the balance of the screw and hope the new one threads right.
I`m wondering if anyone has an old XP they are willing to let go or even a dead one that I can pull the head off of and put on my PC. Thanks guys your the best.
