27ft Boat Restoration
SilverJag
Hi guys,
It's getting warmer out and my dad and I set out to do restoration on our boat. I have not started yet, but before I do I just want to put it out there for any advice/tips/help I can get from you guys.
The entire gelcoat (?) is not only oxidized but 'gone' after years of abuse, so we were thinking of repainting it. First though, I should wetsand (what grit?) to a matte finish, and repaint the entire exterior? I will look into some gelcoat restoration kits as it is currently pretty cracked and broken up (if that makes sense). So I just wanted to clarify with you guys the process of prepping for paint - am I on the right track?
After we spray new paint and clear, will there be a need to machine polish? I have a Griots DA, but I'm not sure if that will suffice (no rotary either).
Any ideas?
SilverJag said:
Hi guys,
Any ideas?
I would recommend to dewax/degrease the whole boat with HD solvent
Sand the whole boat with 150 or 180g paper
Spray with high build epoxy primer
Block sand whole boat 220 to 320g
Fill any pin holes and inperfections
Spray 3 coats Marine Polyurethane
Gelcoat repair kit won't help...............................or
Sand whole boat
spray duratec primer
sand whole boat with 220g
spray gelcoat
sand whole boat 220 /400 /800 / 1200g
compound and polish whole boat
Don't do it, don't do it, don't do it.
I did my 21 ft Crownline last year with M205 and a G110.
After two bottles of M205, some marine polish, Chemical Guys JetSeal 109, meguiars marine wax and a ton of labor, it came out really nice, but I wouldn't start anything you aren't fully prepared to finish.
