1Z products, are they worth it
6']['9
this is probably the only product that i havent used. Im interested in purchasing them but i havent seen much on them as far as detail jobs. Are there any pros & cons with this product. let me know as much as you can if you've used it. Thanks
Sure the polishes are. My biggest con is the fact they contain wax and I have to use alcohol to make sure they got rid of the marring and to ensure 110% that my LSP will bond properly.
Man this system seems too confusing. :confused: how is their smr compared to Menzerna or Meguiars? When it said its durable how durable are we talking?
There's only 3 1z polishes. There really isnt a smr. What product are you referring to when you say durable? Do you mean the Glanz Wax? A lot less stuff than Megs . Technically Menzerna is pure compounds and polishes used by Mercedes and the Maybach that work best with a rotary .
Maybe I can clarify this a bit, or else I'll make it even more confusing :o
There are three "normal" 1Z polishes, these are in the "consumer line" (smaller rectangular cans) and four in the "Pro line" (larger 1-liter round cans). All can be used by hand, DA/PC/Cyclo, or rotary. All are about as user-friendly as such products get.
All contain wax which will provide some protection even without a LSP but which *might* cause some bonding issues with some LSPs unless you do the alcohol wipe as Bill D does.
The three "consumer" line polishes are:
Ultra/Extra Paint Polish ("UP/EP")- Quite aggressive. Will remove most minor marring even from hard clears. Will almost always leave micromarring unless used by rotary (and even then in many cases). Can be used by hand despite its aggressiveness.
Paint Polish ("PP")- A general-use abrasive polish. Comparable to DACP and SSR2.5, but maybe a little milder. Must be broken down fully to leave a ready-to-wax finish. Often best when followed with a milder product.
Metallic Polish ("MP")- A very mild polish comparable to most "swirl removers" and even comparable to aggressive "cleaner waxes". Will not remove much marring, too mild for that. Used right before (or as) a LSP.
Pro versions:
There are Professional versions of Ultra/Extra and Paint Polish that seem to be the same as the "consumer" versions, but might be just a little thicker. These come in the round, 1-liter cans.
The Pro version of Metallic Polish is notable different from the "consumer" version. Besides smelling more "industrial", it's thicker, more abrasive (though still quite mild) and has less wax. It seems a little milder than PI-III MG but it's still not nearly as mild as stuff like P21S GEPC or Pinnacle's PCL. Not quite as mild as FP either, but I can't tell an improvement when I use FP after it.
The final "Pro" product is WaxPolish Soft (WPS)- This is like the "consumer" Metallic only with more waxes. The abrasives seem similar to the "consumer" Metallic. Seems sorta heavy on fillers, which 1z calls "concealers". Works well as a final polish before LSPs or can be used *as* a LSP. Some users report the "concealers" last for months.
Accumulator,
He he, I have a question now: Do you think it's worth getting the Pro MP for Audi Clear?
Pro versions:
Now thats a reply thanks guys for the help :scared
Several of us here would recommend the 1Z Perls shampoo. This is my favorite in between my staple of P21S shampoo. Perls is very high in lubricity and leaves a terrific finish.
Many think highly of this line. :)
I have used 1Z Tiefenpfleger so far. I have tan vinyl interior. I use it after woolite cleanup and it really brightens the looks and leave behind nice sheen ( like satin) .
Geez, I left my house for a couple of hours and what a thread!
...Just because I wanted to start an 1Z thread too...
Similar questions: From the Pro line, I wanna buy the "real industrial" stuff (Pasta Intensiv, High Gloss Polish and Wax Finish O.S.; 5 or 1 liter cans for cutting/polishing/glazing), which contain no silicone.
What are the differences? Any experiences with them?
:xyxthumbs Accumulator.
I think they have several worth-a-look products outside of the polishes. Check out their website, www.1z-usa.com, for loads more info. I really like the glass products, including the glass cleaner and polish, very good stuff. The Tiefen is excellent also, very good durabliity for exterior trim and tires; it'll last through 2-3 washes. Two thumbs up to the Perls and Lackfinish too. I like everything I've tried but I've yet to use the Cockpit Premium, Metal Polish, and the wheel cleaner and tire foam.
1Z products are well worth the money.If you have used them you will understand why I say this. The perls car shampoo is one of the best on the market.
MacGirl- Yeah, I like a few other 1Z products, but I'm trying to use up some of the gallons of stuff I've already, uhm, accumulated :o I tend to buy stuff I like in large quantities in case it gets discontinued/changed and sometimes this can sorta work against me. When I say "gallons", I mean some pretty large quantities ;) I did just pick up the glass polish, though.
ALAN81/SilverLexus- Well, if they'd start selling Perlz in gallons I might be interested. I go through so much shampoo that the little bottles aren't really appropriate for me.
Bence- OK, you got me there :D Sorry, but I haven't tried any of the products you asked about. But I'd say it's a pretty safe bet that they'd work rather well, based on all the other polishes they do so well with.
Bill D- I dunno about the Pro MP being all *that* much better than the consumer stuff, but when you run out of the latter I'd buy the Pro version from now on. I got mine when I sent back that can of MP with the "funny gray matter" in it (which I've never heard back on...). At least the pro might take out *some* very light stuff, the consumer won't do much of anything, at least not on an Audi. I really just use MP as a final pass after other products.
A lot of people on this site love the 1Z products. I tried them (Glanz Wax, Metallic Polish, paint polish and Tiefenpfleger) at least twice each ... unfortunately did not like them and gave thm away.
I love the Cockpit Premium and the Tiefenpfleger. I hate a greasy look on my dash. I have recently bought the Glass Polish and my first impression of it is very positive. 1Z is a premium product but well worth the cost IMHO.
I haven't tried any of the polishes yet, but several friends rave about them.
I've used their Ultimate, Paint, and Metallic Polish. Everything seems to work pretty well as long as you don't mind waxes mixed in with your polishing.
I would say that the most satisfying of the three polishes is the Metallic Polish. It's the easiest to use and does leave a nice shine. It left a VERY nice shine on my dark blue metallic Avalanche. I would rate it better than NXT for sure.
The BEST product they have that I have used is the Perls Shampoo.
I am less than happy with the "Cockpit Premium". It doesn't seem strong enough to remove those heel/shoe marks from plastic door sills. I probably need to move up to the "Plastik-Reiniger" cleaner.
The leather care seems to clean pretty well, nothing exciting.
I absolutely love 1Z Products!! My favorites (and the products I ONLY use are), Tiefengleger,Cockpit Premium,Plastik-Reiniger,Gummipflege ,Lackfinish,Einszett Glass Cleaner (Scheibenklar),and Perls gloss shampoo. The Glass cleaner is THE BEST Glass cleaner! NO STREAKS.Period.(When used with Sonus detail towel).The Lackfinish is absolutely amazing. It actually leaves the paint more shiny than before treatment! The same as the Perls shampoo, great shine and the water rolls off which leaves minimal drying. The Gummiflege has a great applicator (little sponge that creates a no drip or waste application on the weatherstripping).The Plastik-Reiniger is what I use on my wheel-well plastic. Cleans and leaves a perfectly non greasy finish.The ONLY product from 1Z I have tried and don't use is the wheel cleaner. It is a little to harsh for my usage. MAYBE if I was trying to clean neglected wheels but not for the once a week cleaning. All in all you cant go wrong with 1Z! Oh I am waiting for my Glanz wax.(Maybe a replacement for my all time favorite sealant,Klasse)?
