Bigpoppa3346 said:I don't notice any filling with the Blackfire polish. Keep in mind I'm using a PC/UDM, and not a rotary.
In fact, following up with ZAIO or KAIO only improved the finish (even on black), not revealing any marring like one would think. I do see how it could fill if not broken down properly, though.
zoomzoom mazda5 said:This is a Great Topic and i will be keeping a eye on it!..... Thanks rydawg
maesal said:If I can, I'll place a test on thursday with 106FA and RD3.02 removing the oils with IPA or 1z Acrysol and I'll post what I find. But I tried this before with Menzerna Top Inspection and never shown fillers.
rydawg said:This issue is only on very few certain paints. Mine being one of them and is a perfect test bed for testing out true polishing techniques. It's not just the 106 that causes this... Every polish I tested on these same panels along with the same technique failed.
On harder clears I have not had a problem at all. But I will have more on this too.
rydawg said:When you use ZAIO or KAIO, do you do an IPA wipedown before you use these polishes?
