hondaguy2582
had the aiox2 and sg for about a month, i decided to apply another coat. First off, used klasse as a qd(poured into empty container with distilled water), works decent, smooths surface a bit, did not clay. then i applied aio on top and trunk, hood wasn't too bad so i didn't aio again. Then i applied sg to the whole car. Waited about 1.5 hrs to let it dry, then i removed with an mf towel. In the process of letting it dry, i did aio to my wheels and applied 303 to the tires. I must say, 303 goes a long way if you use the turtle wax tire swipes(or eagle one for that matter), two small spritzes of it will do 2 tires, maybe more but i spritzed when i got done after two. Anyway, pics will follow.
