I`m new, but I`m following everyone`s instructions and getting great results - thanks all
The car I`m working on is going to require some work with 3M FI-II Fine Cut Rubbing Compound and then 3M-SMR, which will ultimately be followed by Z5 and probably Z2.
Does the use of the SMR (on the entire car) eliminate the need to clay bar, or does the clay bar do certain thing the the SMR will not do as far as surface prep? Thank.
Bookmarks
