I want to know your method of applying both Polish and Wax using an orbital buffer.
I received my Porter Cable and had an opportunity to speak with a professional detailer that was here in the US at Griots Garage factory, he`s from Toronto and a big purchaser of Griots products, so they flew him in to see their manufacturing operations.
He spent about 1 hour with me in the parking lot covering everthing from two-bucket wash method to using the buffer. Here`s what he said about using it, <strong class=`bbc`>and I would like your method/feedback:[/b]
"After claying the car, rinsing and drying..work small sections at a time, like 2 ft. by 2ft. sections. Apply the polish directly to the pad, small amounts. Work back and forth , then work the area up and down, so that you criss-cross the area you just polished up and down. Remove the polish immediately. Apply polish again if it looks like you need to, or, add just alittle finish wax to the polish pad along with the polish and re-do the section until desired result appears."
Bookmarks
