I washed a 2014 GMC Sierra with DP Power Wash Wash & Wax, Synthetic Sheepskin Wash Pad, and a Cobra Supreme Guzzler Waffle Weave Drying Towel. It was my first time using DP Power Wash and I was very happy with the outcome.
For a couple ounces of this stuff goes a long way!
I used the grit guard to mix the DP Power Wash
An extra spray of water creates mounds of foam! This stuff also smells great, and is very slick.
Before: The truck doesn`t look to bad from a glance but taking a closer look there was a lot of water spots and dirt buildup.
I sprayed the whole car down with water first.
The Synthetic Sheepskin Wash Pad is very absorbent and it can get into those hard to reach places. What I liked about this wash pad is that absorbed a lot of slick foam, wiping the car was an ease. Also the pad did not scratch the truck`s black paint.
The wash pad attracts the dirt taking it directly off the vehicle. A quick rinse of the pad and it is ready to be used again.
Hose down the vehicle again, the foam and dirt easily washes off the car leaving it completely clean.
I used the Cobra Supreme Guzzler Waffle Weave Drying Towel to dry the truck. An advantage to using this towel is that it eliminates the chances of water spots and it is super absorbent, so you don`t have to stop and wring it out. I also does not scratch the vehicle.
The truck is dry and cleaned!
Links to Products:
Grit Guard Dual Bucket Washing System
Bookmarks
