Results 1 to 15 of 15
  1. #1
    Rasky's Auto Detailing RaskyR1's Avatar
    Join Date
    Mar 2009
    Location
    Eden Prairie, MN
    Posts
    5,011
    Post Thanks / Like
    E30 M3, Multi-Step Correction and Partial Wet Sanding
    The owner of this fine example of German Engineering recently purchased the car and wanted me to do what I could to get the paint looking its best within his budget. Upon inspection it was evident that it had been repainted some time ago and that there was some excessive shrink on the top panels and a few other paint issues that needed to be addressed.
    Car as it arrived (nice and clean)
    Shrink on the hood can be seen from the lack of gloss and distorted reflection
    Washer nozzles removed for sanding and polishing
    Close up of shrink
    Sanded with 1500/3000 grit Meguiar’s sanding discs (hand and DA)
    After compounding with the Rupes LHR21 and KBM205 method
    Close up of shrink on the spoiler
    At a distance
    Close up of spoiler after sanding and compounding
    At a distance…notice the difference between the spoiler and the trunk
    Spoiler removed
    A few areas on the car had these “goose bump” protruding from the paint. I’m not 100% certain what causes this but I’ve seen it before on repaints. Its likely solvents or moisture trapped under the paint, possibly in the primer or base coat, which are trying to escape. I don’t suggesting trying to sand these defects out, for obvious reasons, but it looked bad and I decided to test out sanding in a discrete area, which turned out great. It’s not 100%, but a huge improvement. I lightly sanded them here so they were easier to see. The touched up chip can be used as a reference point.
    After
    Swirls and RIDS throughout
    50/50 shot
    I spent about 10-12hrs carefully wet sanding and compounding….
    An example of when the rotary is the better tool for the job.
    Great example of where the Rupes TA50 and 2” pads shine
    Finished shot prior to LSP….two different aperture settings
    I like this one
  2. #2
    Join Date
    Mar 2009
    Location
    Eden Prairie, MN
    Posts
    5,011
    Post Thanks / Like
    Re: E30 M3, Multi-Step Correction and Partial Wet Sanding
    After pics….I had hoped for sun, but I’m grateful that the owner made it home without getting rained on.
    As always, thank you for viewing my work.
    Rasky
  3. #3
    PapaChop's Avatar
    Join Date
    Apr 2014
    Location
    Augusta, GA
    Posts
    91
    Post Thanks / Like
    Looks good. Does the TA50 require much of a compressor?
  4. #4
    Opti Coat Pro Certified Orinda Auto Detail's Avatar
    Join Date
    Feb 2012
    Location
    Bay Area
    Posts
    2,081
    Post Thanks / Like
    CHAD FTW!!!! Nailed it!! Although I would expect nothing less! Great work!
  5. #5
    Dave@Lake Country Mfg. David Patterson@LakeCountry's Avatar
    Join Date
    Oct 2013
    Posts
    54
    Post Thanks / Like
    Great work! Pretty awesome car also!
  6. #6
    Super Moderator Pats300zx's Avatar
    Join Date
    Dec 2001
    Location
    Middletown, Delaware
    Posts
    13,582
    Post Thanks / Like
    Great job Chad
    Only Z Best Detailing-Automotive Concours Detailing Services
    http://ozbdetailing.com
    https://www.facebook.com/ozbautodetailing
  7. #7
    mnehls86's Avatar
    Join Date
    Aug 2013
    Location
    Southern Ca.
    Posts
    1,543
    Post Thanks / Like
    Great work! I got excited when I saw you had a new thread up and this one did not disappoint. Those first 3 hood pics were amazing.
  8. #8
    Detailers Workshop The Driver's Avatar
    Join Date
    May 2012
    Posts
    2,418
    Post Thanks / Like
    Amazing, glad to see a worth car go to a worthy detailer.
  9. #9
    Join Date
    Mar 2009
    Location
    Eden Prairie, MN
    Posts
    5,011
    Post Thanks / Like
    Quote Originally Posted by PapaChop View Post
    Thanks! The TA50 consumes 11.7 CFM, so if you`re running it a lot you`ll want a good compressor. If it`s just for a few areas a smaller one should be okay.
    Quote Originally Posted by Jsmooth View Post
    Thanks Joseph!
    Quote Originally Posted by David Patterson@LakeCountry View Post
    Thanks David!
    Quote Originally Posted by Pats300zx View Post
    Great job Chad
    Thanks Pat!
    Quote Originally Posted by mnehls86 View Post
    Thank you! I enjoyed working on this car and enjoy doing write ups on jobs like this.
    Quote Originally Posted by The Driver View Post
    Thanks for the kind words!
  10. #10
    I'm Greg :) Greg Gellas's Avatar
    Join Date
    Oct 2009
    Location
    Northern NJ
    Posts
    822
    Post Thanks / Like
    As always Awesome work Chad!!!
  11. #11
    jtford95's Avatar
    Join Date
    Aug 2007
    Location
    Willow Grove Pa
    Posts
    2,117
    Post Thanks / Like
    Came out great! Really nice.
  12. #12
    You Mirin'? The Gloss Boss's Avatar
    Join Date
    May 2011
    Location
    Cape Girardeau, MO
    Posts
    149
    Post Thanks / Like
    Bam! That`s how it`s done!
    The Gloss Boss, LLC
    Kris Metje, Owner
    http://theglossbosscape.com
  13. #13
    AtoZDetailing's Avatar
    Join Date
    Feb 2014
    Location
    Toronto, Ontario
    Posts
    79
    Post Thanks / Like
    Awesome work! One of my favorite cars
  14. #14
    Wax Waster Ronkh's Avatar
    Join Date
    Mar 2008
    Location
    SwFL
    Posts
    27,090
    Post Thanks / Like
    MMMMMMMMMMMMMM
    Beautiful !!!!!
    Formerly the "Best Detailer", now just Super Wax Waster Man. Not necessarily tactful, but normally right. It`s good to be da King !!!
  15. #15
    Just a regular guy Todd@RUPES's Avatar
    Join Date
    Feb 2009
    Location
    Oviedo/Stuart Florida
    Posts
    15,278
    Post Thanks / Like
    Awesome work Chad! Great to see you posting your masterpieces
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Replies: 4
    Last Post: 06-28-2014, 11:41 PM
  2. E30 M3, Multi-Step Correction and Partial Wet Sanding
    By RaskyR1 in forum Click & Brag -The Detailers Showcase
    Last Post: 06-06-2014, 07:40 PM
  3. Replies: 5
    Last Post: 05-15-2014, 08:39 AM
  4. ‘14 Chevy 2500 HD, Multi-Step Correction and Opti-Coat Pro application
    Last Post: 05-14-2014, 02:43 AM
  5. Red Jewel Camaro RS + Opti-Coat Multi-Step Correction
    By ReflectionsADS in forum Click & Brag -The Detailers Showcase
    Last Post: 09-25-2013, 04:25 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
