Welcome to Autopia.org. You are viewing as a guest.
09-09-07, 07:12
#49 (permalink)
| | Banned
WilliamHBonney is offline
Join Date: Mar 2007 Location: USA!!! Posts: 1,415 | Re: Ultima Paint Care Challenge Quote: |
Originally Posted by RCBuddha I'd venture a guess that:
1. People were on vacation
2. It was too damn hot to work
3. Not many people might have OS, CS and Ultima to do a comparison test
I would also like to see a comparison; I've got an informal test currently going on my hood. | I have all three and as soon as I get some time I am going to run a test. Hopefully by next weekend. | |
09-09-07, 07:14
#50 (permalink)
| | Banned
Originally Posted by blkZ28Conv Challenge ends September 1, 2007
Did anyone partake? | I did it but I never wrote anything up. I been really lazy lately and got kinda turned off on Ultima after poor results on a few cars. | |
09-09-07, 08:07
#51 (permalink)
RCBuddha is offline
Join Date: Sep 2004 Location: SoCal Posts: 1,458 | Re: Ultima Paint Care Challenge Quote: |
Originally Posted by WilliamHBonney I have all three and as soon as I get some time I am going to run a test. Hopefully by next weekend. | Sounds good, are you going to do all three on hood, and then compare or ?
__________________ Proud Member of:
Club HITACHI, PC, Cyclo & MENZERNA | |
09-09-07, 08:19
#52 (permalink)
| | Banned
Originally Posted by RCBuddha Sounds good, are you going to do all three on hood, and then compare or ? | Yes I am, the only flaw that I have in my testing is that I was going to prep three spots on the hood with UPPP, ZAIO, and ???
I dont have any other Optimum products other than ONR. Should I just use some Menzera 106FF or should I leave it as is or maybe KAIO, or JWs PS?
I just dont want people to ***** about the surface prep. Now that I think about it I only have my rotary because my UDM got sent back and my new one will not be here until Tuesday.....
Thoughts on surface prep? | |
09-09-07, 10:41
#53 (permalink)
porta is offline
Join Date: May 2005 Location: Sweden Posts: 1,091 | Re: Ultima Paint Care Challenge PO106FF with a Ipa-wipedown? | |
09-09-07, 06:12
#54 (permalink)
RCBuddha is offline
Originally Posted by porta PO106FF with a Ipa-wipedown? | That's what I was thinking as well. Do it for all three WHB, that way you have equal prep for them to apply to.
09-09-07, 09:02
#55 (permalink)
| | Banned
Originally Posted by RCBuddha That's what I was thinking as well. Do it for all three WHB, that way you have equal prep for them to apply to. | Yeah I can do that but to be fair it does say that you should use the UPPP to get the best results. | |
09-09-07, 09:54
#56 (permalink)
RCBuddha is offline
Originally Posted by WilliamHBonney Yeah I can do that but to be fair it does say that you should use the UPPP to get the best results. | If that's the case, then buy 4oz of Poli Seal from Patrick @ Excel Detail. That way, you have paint prep for all three. Here's the link for ya: Optimum PoliSeal (4oz)
Only $5.00 and you can do a side by side by side test of all three product lines. I would even repeat the same test on the vehicles that you found Ultima not to last on. You never know, it might have been the paint that didn't respond well to the product.
For example, I did Clay/ZPC/Z6 wipedown/ZFX'd Z5 (x2)/Z6 Wipedown/Z2Pro (x2) on a Nissan Altima (2004). It was driven for three months in the Northern California. When I saw it at the 3 month mark, the Z was DEAD. No beading, no shine, DEAD. Yet, on a 1997 Civic that I did Zaino on, the beading lasted well into 4 months. My guess is that some products work better on some paints more so than other paints.
09-15-07, 12:37
#57 (permalink)
ufourya is offline
Join Date: May 2006 Posts: 21 | Re: Ultima Paint Care Challenge O.K., I got my Ultima Sample Kit yesterday. Today I decided to do a little test. I polished with OP and divided my hood in two with tape. On the driver side, I further polished with Sonus #3 Final and on pass. side with UPPP - all polishing with a PC. Diluted IPA wipe after OP, but just MF towel after the UPPP. Then I applied UPGP on the pass. side and Optimum OS on the driver side as per instructions. The OS is crystal clear and the UPGP is slightly milky in the bottles.
Of course it's way to early to tell anything about longevity of product, I do have some initial observations. The PPP which was next to the tape and consequently didn't get polished out as much as the rest, set up a bit and needed to be removed with a dampended MF - took some rubbing. You definitely don't want to let this stuff sit around and get dry. I could see a whole lot of work if it is applied too thickly or let set up. Opti Seal goes on a bit easier than the Paint Gaurd Plus - I used the recommended MF covered foam for PGP and the foam for OS - both by hand, of course. It seems easier to tell where you've been with OS. Both flash dry.
To my aging eyes there is no difference in the look of the two products under halogen lights or outside in the sunlight. They both look good. The only difference right now is in the slickness. UPGP is slicker - feels very nice.
I will apply another coat of each after 12 - 24 hours and then fill you guys in on what happens with updates on beading, appearance after washing, etc. | |
09-16-07, 02:32
#58 (permalink)
arenner80 is offline
Join Date: Jun 2006 Posts: 75 | Re: Ultima Paint Care Challenge What pads are you guys using/recommending on your PCs to apply the Ultima paint prep+? I purchased the sample kit, and am planning on using it on my pewter 01 GMC. thanks | |
09-16-07, 04:56
#59 (permalink)
rwisejr is offline
Join Date: Feb 2007 Location: LI NY Posts: 468 | Re: Ultima Paint Care Challenge Quote: |
Originally Posted by arenner80 What pads are you guys using/recommending on your PCs to apply the Ultima paint prep+? I purchased the sample kit, and am planning on using it on my pewter 01 GMC. thanks | Polishing pad !!!
Ron
2 Rotary's,Flex,UDM,PC,PC7424XP,Aztec HotRod,Camspray 1500A PW,CamSpray Foam Cannon | |
09-17-07, 07:28
#60 (permalink)
| | Time's a-wastin',speedy!
TortoiseAWD is offline
Join Date: Jun 2001 Location: Omaha, NE Posts: 3,397 | Re: Ultima Paint Care Challenge Quote: |
Originally Posted by arenner80 What pads are you guys using/recommending on your PCs to apply the Ultima paint prep+? I purchased the sample kit, and am planning on using it on my pewter 01 GMC. thanks | For paint cleansing, use a polishing pad. To remove *minor* defects, you can use a SwirlBuster pad. I've been able to remove very light marring with that combo.
Tort
If you wish to make an apple pie from scratch, you must first invent the universe. — Carl Sagan
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 03:51. | | | |
