Welcome to the Autopia.org. You are viewing as a guest. By joining our FREE community you will be able to interact with others. Plus, when you join you will receive instant coupon codes for special discounts with our sponsors. Registration is fast, simple and absolutely free so please, join our community today!
Well I arrived at 9:30am to start the fun and games. After talking with the owner and setting up. It was 10:00, I had to start, and when the sun hit it, it was a different story.
The paint was covered in spiderwebbing, and had rotary trails all over the hood.
The wash Optimum car wash
Tires/wells Optimum car wash and a little dawn mix with a wheel brush.
The Gameplan
I started to use a few products and they were doing ok, but not good enough. With the org. wg pad. Then I used the org. edge pad, since my green pad was still wet from a previous use. I took out my heavy hitter 3M heavy cut, that did the job. It did leave a little haze on the paint. So then I used Optimum Polish to bring back the shine and depth. I then rewashed the car with my foam gun. I used a mix of optimum car soap and dawn soap. The owner wanted me to put zaino on as the last finish. Zaino Z-5pro was used.
