Applying Vanilla Moose - By hand or PC??
dschribs
Active member
I only have Meg's pads for now - a few of the W-9006 and a few of the W-8006 - for my PC. My question is, when applying Vanilla Moose - should I do it by hand with a foam applicator or use the W-9006 pad from Meg's?? Would there be any benefits to either?? Also, if the pad is the way to go - what speed should the PC be set at and for how long does it need to be worked in??
Thanks!!
PC only here. I find you get more of a polishing effect via PC than by hand. I like to use a light polishing or finishing pad, which is determined by if I polished before this step or not and use speeds 5 and 6.
Same as Jason, VM with a PC using either a light polish or a finish pad. The nice thing about VM is you can apply it everywhere: windows, plastic, trim, weatherstrip, etc..
