i dont think it would work as good as using an RO
its feels a bit grippy, might be alot of hard work and tiring to do by hand
in fact it looks very similar to
Menzerna Final Finish, same color and texture, but tends to smear across the panel rather than buff away cleanly
you would only use the swissol medium cleaner if you have light swirl marks. I dont see the point of using it though to remove swirls, just use a much cheaper abbrassive polish instead. Then use the swissol light fluid cleaner and apply the wax. Much easier imo
re wash, i use either the Zaino wash or Meguairs soft wash - whichever i reach for in the cupboard
we have very strict water restrictions in Aus now, soon we wont be able to use a home high pressure washer, only use water to clean the windscreen. So ill have to start using the Quick and Easy water saving wash, or go to the local machine car wash at night and wash the car using their recycled water
