By joining our FREE community you will be able to interact with others. Registration is fast, simple and absolutely free so please, join our community today. When you join, this box is replaced with our live chat! |
03-20-07, 02:21
Cassman is offline
Member of another forum has epoxy paint drop problem
As a favor to him, I am quoting his post here:
I have a new 07G.. and somehow paint accidentally splattered onto my car.. I have drops of paint on my bumper and one on my hood..
any ideas how to get it off? It was noticed after it was dry and not sure how long its been on there..
I am freaking out and not sure what I should use to get it off?????
Apparently, he has been told that the epoxy from a garage floor is impossible to remove. If anyone has any ideas, I'll refer him to this post. Thanks.
03-20-07, 02:35
Wetwerks is offline
Re: Member of another forum has epoxy paint drop problem
Has he tried clay yet? Thats what I would start with.
Walter
Co-owner
03-20-07, 02:46
Cassman is offline
Walter
Co-owner
Yeah, that is what I told him. I sent him a link to this site, so maybe he will chime in. Otherwise, it seems like a unique enough situation that it may assist other members here with a present or future similar problem.
03-20-07, 03:17
Changeling is offline
3m machine oil has been quoted as removing fresh/somewhat paint. Really don't know. Good luck. Apply and "Gently rub with a very soft rag (cotton cloth)".
Changeling
03-20-07, 09:14
IsaG35 is offline
Hi Guys,
I am the 07G owner with the epoxy problem.
Just to start off.. I am a female  my husband is the one who got epoxy garage floor paint into my car..
It is hardened on their good as we didnt notice the problem till a few days later..
I took it to a body shop and a dent place.. basically the epoxy is stuck on there and they are saying its harder than the paint..
They said the clay bar wouldnt work because its epoxy and its hardened too much like cement..
I am taking my car to the dent place tomorrow and the guy said $125 if he can fix it - if not its free.. so I am going to try that..
03-20-07, 11:28
ScoobNewb007 is offline
if you want you can try some thing called the blob eliminator.
I don't know will it work on epoxy paint, i guess you can contact someone at langka.com or search the web for something similar to langka's blob eliminator and email about the epoxy paint.
the blob eliminator is around 20bucks before shipping so you might give it a shot if you don't want to spend 100+ bucks to remove at the body shop.
03-21-07, 12:17
sneek is offline
i dont think that would work
03-21-07, 12:44
admac is offline
langka "works" based on the fact that it's used on a soft and not very durable paint. i can't think of anything really other than using a very straight sanding block like a meguiars unigrit and then working it down ever so gently and avoiding the good paint areas as much as possible. unless it's actually penetrated the clear (which doesn't seem possible) it is at least plausible that it can be sanded off. of course, you run a very high risk of sanding through your clear.
03-21-07, 12:51
dmxsoulja3 is offline
I'll be honest, if I didn't have an autopian near me to try wetsanding the area in the smallest area possible near the damage with unigrit and use a PC or Rotary to finish it down, not expecting 100% perfection but just to "blend" it in per say, I would probably live with it...Everytime I've ever seen a car leave a body shop for something small like a scratch or some door dings, they have swirls everywhere else when they didn't before, or recently that guy posted they hazed his clear really bad. You should post where you are located to see if someone local can come help you out
03-21-07, 07:04
Wetwerks is offline
On an extreme situation such as this when clay will not work...you could go the plastic razor blade route, but care must be taken and will also require some light compounding, polish to bring the finish back. We have used this method with actual cement drops that hardend on work trucks.
Walter
Co-owner
03-21-07, 01:37
admac is offline
you could also try the single sided razor scraping technique. use a single sided razor and bend it slightly outward as you scrape the surface of the drop. bend it in such a way that the middle of the blade is extended downward while keeping the edges of the blade away from the paint. then you can just scrape like a paint scraper. it's how painters can get rid of runs and nibs in their paint jobs.
03-21-07, 03:45
South Florida Style
themightytimmah is offline
Plastic razor blade might work, I'd be afraid the paint would come off with the epoxy.
I'd probably take a piece of 400 grit paper, wrap it around a pen/sharpie/etc and knock off the top of the epoxy, then switch to 1500 on a pen/sharpie/etc and get the epoxy almost level with the paint. I'd finish sand it with 3000 to blend/level it in, then compound and polish it out.
I did this to remove cured epoxy from my Grandpa's Taurus (he tried to glue a mirror back on and dripped all over the paint) and I was able to do it without removing more than a tiny bit of clear. It was a helluva nailbiter though, I was pretty worried about screwing up the 400 grit stage. This is probably what the body shop guy is going to do - just hope he doesn't sand too much or mess up washing the car/finish polishing and leave swirls all over the car.
Edit: Make sure to tape off around the blob when 400 grit sanding. I didn't do it when I fixed the Taurus, but it would probably make life a lot easier in the future.
