Old 09-11-04, 09:26   #1 (permalink)
Senior Moderator
Brad B.'s Avatar
Brad B. is offline
Unhappy Chip repair...in three simple weeks!
I had this horrible chip on the rear fender lip of the Carrera. It was the size of a pencil erasor, perhaps sightly larger. Chipped right down to the primer. But it was one of those blister types where the edge leading up to the open hole was raised and looked like a miniature volcano.
I touched up the hole with factory touch up. I slowly layed it paint over the course of a week. I would thin it with laquer thinner to make it flow better and use a 000 art brush to lay it in the best I could. It matched but the texture was wrong and it wasn't flat due to the volcano-effect surrounding the filled in chip.
I tried flattening it with Langka but it destroyed the metallic effect. I then built it up again and wet sanded it flatter and tried touching it up one last time with the brush. It wasn't bad. Still, the volcano look was distressing.
I decided that I had to flatten the volcano more and while picking on it some more, part of the chip, apparently a loose paint-blister, popped off! So now I had a hole twice the size of the one I started with. This was almost dime size now!
So after a lot of cussing, ranting and pacing around the car, I decided to take laquer thinner and get all the paint out of the chip and start from scratch.
I went to the art supply store and bought myself an air brush. I have some extra paint from when the dealer painted my new euro front bumper cover this past Spring. So I thinned the paint 50/50 with laquer thinner and began to layer in paint in the chip. I cut varying size holes in a postcard using an adjustable leather hole punch. I shot the airbrush through the card at the chip and moved the card around the chip filling the area evenly. I did this for a whole day slowly building up the paint thickness. Finally I sanded it smooth with 2000 grit sandpaper. It was perfectly flat and smooth. Then I started spraying over the chip. Spray and sand. Spray and sand.
Naturally whenever I touch the metallic paint I destroy the metallic look so when I got it perfect I gave it one final "beauty" shot.
This required me to not only spray the touch up spot, which had grown to the size of a quarter, but I had to blend it into the surrounding lip. I was lucky in that I could keep the repair on the vertical lip. It gave me a natural edge to blend up to. But I still could not mask it off in a traditional sense. I tried and it left a hard edge. (I had many attempts that were "erased" with thinner or compound) What I ended up doing was cutting a template of the curved lip that I was painting and taping it to spacers I rigged so the masking was 1/2" off the surface. This way I could angle my spray and get the area I needed to spray but it would never create a "hard" edge. It feathered out nicely. The farther away the paper was, the more feathered it was. I sprayed an area the full height of the lip and about 6" long. It is very solid in the center 2" and it feathers out the rest of the way.
My next issue was protecting the metallic. I couldn't touch it or it changes the look. It didn't have the gloss of the surrounding paint. I bought two types of some airbrush paint made for touch up put it looked really yellow-ish and on my test panels (I painted half a dozen metal test panels metallic silver-blue with extra paint and tried different clear coats and techniques) it was un-impressive and very orange-peely. Finally I went to the auto paint store and bought some Dupli-Color spray clear in a can. The paint looked pretty good on my test panels but the spray pattern from the can was over 4" wide. I could never control that for my little touch up job. So I sprayed the Dupli-Color in the airbrush bottle and then airbrushed that onto the test panel.....it worked!
So that's what I did. I finally finished up by spraying the clear. I sprayed as heavy as I dare to get it as smooth as possible. Tomorrow I will compound the surface "just a little" to improve slickness. But for all practical purposes I am done!
I wish I had taken a "before" or "during" picture. But I had no idea what a big process this would be or that it would turn out so incredibly well. If it hadn't, I would never have told you!
I was so upset with this big mess and my wife was so pissed with my complaining that one day she just erupted: "Just sell the damn car!" Well, I guess I can keep it now. Phew!
Find the chip...I dare you!
Old 09-11-04, 10:22   #2 (permalink)
The KYdetailguy
ZJ JIM 96 is offline
Amazing job. Was this your first shot at air-brushing? If so, how hard was it to pick up, and can you recommend a setup?
Here's a guess at the spot, but I sure wouldn't put money on it:
Old 09-12-04, 12:03   #3 (permalink)
Dave Holmes is offline
Brad, I'm not even going to try to find the chip. It looks amazing.
I'm in the process of doing some chip repairs, and am getting frustrated with my multiple attempts using a brush and/or toothpick. I've often thought an airbrush would be the way to go, and you just validated my thought with your repair! If you don't mind, could you post specs on the airbrush setup you used, and more info on the learning curve? Thanks.
Dave
Old 09-12-04, 12:09   #4 (permalink)
I Hate College
NavindraLR's Avatar
NavindraLR is offline
wow... u did a good job... i wish i could do what u did on my car... wanna come over and help??
i cant find the chip.. mind tellin us where it is now?
my gallery:
Old 09-12-04, 11:45   #5 (permalink)
Senior Moderator
Brad B.'s Avatar
Brad B. is offline
Thanks for the compliments!
The chip is (was) pretty much dead center in the vertical section of the fender lip, facing the camera.
ZJ...you're wrong! Yippie!
Dave...I did quite a bit of research on airbrushes and for this type of repair the Paasche Type H, single action brush is the best. (I used a size 3 tip-standard) It cost $49. I also purchsed an inline moisture filter and several bottles so I could have each filled with different paints, thinner, etc.
I set my air compressor at 65lbs pressure. You can buy a small hobby compressor to run the brush or even use canned compressed air.
It was very easy to learn to use since it was a single action brush. Not much different than using a spray can. Just WAY more controllable. I mastered it in an hour.
Old 09-12-04, 08:00   #6 (permalink)
Huy
Trying to keep it clean..
Huy's Avatar
Huy is offline
Contact: Send a message via AIM to Huy Send a message via Yahoo to Huy
Holy cow, excellent work Brad!
PS: Long time no see!
Please call customer service, ext. 745
Old 09-14-04, 08:29   #7 (permalink)
The KYdetailguy
Originally posted by ptownTSI
hey are you jim hef from jeepsunlimited?
No. I have the same user name at JU, I'm just not as active over there as I once was.
I recognized your name from there, too, but didn't realize you were in Cali. It's probably worthwhile to look, like you are, for a pro to do the first job, then work on maintaining it. Our ZJs can be a bear to get done right.
Welcome to Autopia.
Old 09-14-04, 09:21   #8 (permalink)
Bill D's Avatar
Bill D is offline
Moderators, it's clear as day this post needs to be in the Hall of Fame.
I've printed it for future reference. Thank you Brad!
Brad,if possible could you take a photo of all the materials used, I see the airbrush gun but could you also show the punch,paint,etc.
That would be great! Thanks!
my product collection
My Detailing Credo
Old 09-14-04, 09:28   #9 (permalink)
Brad- What a great job! That's really something. I have experience with the Paasche, but there's just no way I could do such a fine job
Great example of patience, perseverance, and plain old *ability*. Not to mention courage and self-confidence....it's not everybody who'd try to fix the metallic paint on a Porsche for their first airbrush project.
Old 09-14-04, 09:38   #10 (permalink)
Bill D's Avatar
Bill D is offline
Accumulator, I just saw that Paasche in the Micro Mark catalog, looks like the one Brad has costs half (Type H vs. Type VL) .
My Detailing Credo
Old 09-14-04, 11:27   #11 (permalink)
Senior Moderator
Pats300zx's Avatar
Pats300zx is offline
WOW..that came out amazing...beautiful work Brad...
Old 09-14-04, 11:48   #12 (permalink)
1Z Addict
Macgirl's Avatar
Macgirl is offline
Exclamation NICE WORK
Brad,
You have extreme patience. Would love to see that repair in person someday. Again very nice work and write-up, it's a shame you didn't have the photos to go with your descriptions.
'96 Jeep Cherokee Country - White - Gray Leather Interior
'02 Volkswagen Passat GLX - Reflex Silver - Black Leather Interior - 5 spd Manual
LinkBacks (?)
LinkBack to this Thread: http://www.autopia.org/forum/car-detailing/43937-chip-repair-three-simple-weeks.html
Posted By For Type Date
AudiWorld Forums: Hey there! This thread Refback 11-13-06 09:02
